pankaj.garg29
Set Default Setup Type on Setup Dialog
We are using Advance Installer Enterprise Edition and Version is 10.6. We have specific requirement in installer. We have added 2 Setup type on Setup Dialog screen. We need one of them default selected and user do not need to select explicitly the default one.
We dont know how to do it. Please help us for the same.
Thanks & Regards
Pankaj Gupta
Irina
Re: Set Default Setup Type on Setup Dialog
Hello and welcome to our forums!
I am afraid I do not understand very well your request.
Can you please send us the .aip file to support at advancedinstaller dot com so that we can investigate more?
Also, a more detailed step by step description would help us.
Kind regards,
Irina
Ecaterina Irina Grosu - Advanced Installer Team
pankaj.garg29
Ok, I will send the aip file and detailed explanation on mentioned email id.
Thanks & Regards
Pankaj Gupta
pankaj.garg29
Please find attached image. This image showing setup dialog screen with two options "Typical" and "Custom". Currently none of the options are selected by default so "Next" button is not coming.
What we want, as user comes on this dialog, "Typical" option coming selected and "Next" button is visible by default.
That's it.
Please help us in this feature.
Thanks & Regards
Pankaj Gupta
pankaj.garg29
That's it.
Thanks & Regards
Pankaj Gupta
SetupDialog Step
SetupDialog Step
Irina
Hi Pankaj Gupta,
In the theme you are using, we do not have support for this.
The buttons used for typical and custom installations are predefined PushButtons that do not have an attribute to make them selected by default.
We can suggest you different workarounds:
  • - One would be to choose a different theme, like Graphite, that has this dialog implemented with radiobuttons, which have a property "Selected" that you can use for your purpose.
    Please be aware that by changing the theme, all your changes made over the current dialogs will be deleted, as by changing the theme, the new theme is loaded along with all the contained dialogs.
    - Another workaround would be to create your own dialog to meet your needs.
Do not hesitate to contact us in you have further questions.
Kind regards,
Irina
