dornseiffer
Warnings using the Windows App Certificate Kit
We are using Advanced Installer 11.3 on Windows 7 Professional (6.1.7601.65536) , framework 4.5.2.
The Windows App Certification Kit (3.4) test has passed with warnings. One of them, the "Write appropriate Add/Remove Program values", tells us that
some registry entries have not been created by the Installer; see Warning attachment.
So we can see that the InstallLocation registry key has not been created for these two components.
Below, you can see the Prerequisites that are being installed:
On the Product Details page, the "Register product with Windows Installer" option is checked:
Product Details.png (8.92 KiB) Viewed 1834 times
We tried to solve the problem with adding the missing key on the Registry page.
One of the Technical Requirements for the Windows Certification Kit says that some registry entries should be created automatically by the MSI installer:
DisplayName, InstallLocation, Publisher,...
The results of the test tell us that only the InstallLocation key is missing for the two prerequisites described above ( Microsoft Database Engine and Crystal Reports for Workstation ).
Does anybody have an idea to solve this issue ?
Best regards.
Re: Warnings using the Windows App Certificate Kit
Indeed. this is happening because the Microsoft Office Access database engine 2007 installation package does not creates its own InstallLocation registry entry. The same for the Crystal Reports For Workstation prerequisite.
As I understand, you already tried to create the related registry entry in the main installation package, in the Registry page. It didn't worked. However, can you please tell us how did you created the registry for the related prerequisites?
For example, for the CRRuntime_32bit the Location registry entry should have the following value:
[INSTALLDIR]Crystal Reports for .NET Framework 4.0\Common\SAP BusinessObjects Enterprise XI 4.0\win32_x86\
where the INSTALLDIR property seems to be set with the value of the ProgramFilesFolder property.
Let me know if that helped.
