osherk
Save all user inputs from SQLConnectionDLG into a web.config
I wonder what is the best way to save all user inputs from SQLConnectionDLG into a web.config file which is located under [APPDIR].
Thanks!
Re: Save all user inputs from SQLConnectionDLG into a web.co
In order to create the config file, you can use the XML Editor feature. Please take a look on the How do I import and edit an XML file? article with related information for hints and guidance.
osherk
I opened web.config file which is in 'Application Folder' and edited it as the attached screenshot.
Before running the advanced installer, the web config has only the following tag: <connectionStrings/ >
After running the AI I expected to see in the file the following:
<connectionStrings >
<add name="MyConnString" connectionString="Data Source="localhost";Initial Catalog="Billing";Persist Security Info=True;User ID="sa";Password="*****"" providerName="System.Data.SqlClient"/>
</connectionStrings >
But the file has no changes at all after running the AI. Did I expect something wrong? Did I set something wrong? What did I miss here?
******** Important Remark: if I use the 'Test' for the xml file, it is updated OK! *****************
Many thanks!
