osherk
management studio of SQL Server express 2008R2 x64
What is the best installation of sql 2008 R2 management studio in the installer's defined prerequisites?
If I install only SQL Server express 2008R2 x64, the management studio is not installed with it.
Thanks!
Re: management studio of SQL Server express 2008R2 x64
If you want to add the SQL Management Studio to the installation package, you will need to add it as a Pre-Install prerequisite.
So, in the "Prerequisites" page you can add the related prerequisite using:
  • [ New Package Prerequisite ] toolbar button to create a new prerequisite using files from disk.
  • [ New URL Prerequisite ] toolbar button and add the download URL of the prerequisite.
Please keep in mind that this type of prerequisite is created with default settings, so you need to configure it manually. The best way to see what install conditions you should use is to install the prerequisites on a clean machine and see what changes take place.
You can also take a look on the Add prerequisite article which may be useful to you.
osherk
Thanks!
but I get error 'ODBC timeout'. I attache my prerequisites. Please tell me if there is something wrong there...
Please note that starting with SQL Server 2008R2 SP2 (up to 2014) the SQL Server setup package cannot be installed as a Feature-based or Post-install software prerequisite due to a SQL Server setup problem. For details, please check the Why the SQL Server installation hangs? FAQ.
The SQL Databases Browse functionality lists all available SQL Databases from a Microsoft SQL Server. Through the login timeout you can set the login timeout interval (in seconds) for this database connection. Please check the Why doesn't SQL Browse work as expected? article which may be useful to you.
In order to browse for SQL Servers and databases from an SQL Server, please take a look on the How to browse for SQL Servers on the network? and How to show the available databases from an SQL Server? articles with related information for hints and guidance.
osherk
Hi Daniel,
My problem is not solved and I can't move on with the installer because of it...
Please see my remarks bellow regarding to your previous answers:
1. Please note that starting with SQL Server 2008R2 SP2 (up to 2014) the SQL Server setup package cannot be installed as a Feature-based or Post-install software prerequisite due to a SQL Server setup problem. For details, please check the Why the SQL Server installation hangs? FAQ.
I didn't try to install SQL 2008R2 SP2 as a Feature-based but SQL 2008R2 (please see my screenshot). In addition I couldn't find the problem in the article: "Why the SQL Server installation hangs?"
2. The SQL Databases Browse functionality lists all available SQL Databases from a Microsoft SQL Server. Through the login timeout you can set the login timeout interval (in seconds) for this database connection. Please check the Why doesn't SQL Browse work as expected? article which may be useful to you.
It's the same article like -"Why doesn't SQL Browse work as expected?" I couldn't find the problem in it. In addition where can I change the
ODBC timeout?
3. In order to browse for SQL Servers and databases from an SQL Server, please take a look on the How to browse for SQL Servers on the network? and How to show the available databases from an SQL Server? articles with related information for hints and guidance.
I did the operations like the ones in the youtube film, it's not a solution to my problem.
Thanks!!!
