dornseiffer
Cannot delete custom action
We are using Advanced Installer 11.3 on Windows 7.
On the Custom Actions page, we cannot delete a newly created action in the Install Execution Stages.
Having selected the created action, the Delete button is enabled but nothing happens when clicking on it.
Custom Actions.png (32.01 KiB) Viewed 2896 times
Thx for your help.
Re: Cannot delete custom action
Please note that the RemoveFolders and RegisterProduct are standard actions and these standard actions cannot be removed from the installation sequence.
However, the Delete toolbar button should not be enabled. It should be disabled. Can you please make sure that one of these RemoveFolders or RegisterProduct standard action is selected?
dornseiffer
Thx for your response.
I confirm that the standard action is selected.
I also have a question.
In the Files and Folders page, I created a File Removal item whose name is a standard file path ( see attachment ).
When building the package, an error says that the file name is invalid.
Thx for your help
Please note that in the Name field from the File Removal Dialog you should add the name of the file that will be removed, not the path to the related path.
So, if you want to remove a file from the related directory, you need to create the folder structure first. After this step you can create the file removal operation. Please use the attached image for your reference:
If you have other questions, please let me know.
