owe911
how to show an TXT from an ini file
hi,
what should i do if i want to show a String read from a ini file in the dialog ?
i mean read a sting from a ini file and shown as a static text in the dialog
anyhelp is appreciate!
Re: how to show an TXT from an ini file
For this, you can create a XML Search operation in the Search page. For details, please take a look on the Creating an XML Search tutorial which will guide you step by step in the process of creating a valid and working XML custom search.
Also, I've attached a sample project which implements a similar scenario. During the fist time install, the user is prompted to enter some information.
To perform an upgrade the following steps need to be done:
  • increase the product version from the Product Details page;
  • generate a new ProductCode when prompted;
  • build the project;
  • run the installation package;
When running the upgraded version, the related fields will be filled automatically, so the user don't have to enter once again the related information.
Your Application.zip
(3.71 KiB) Downloaded 259 times
owe911
hi dan
thans a lot!
problem solved !
owe911
Dan wrote:Hi,
hi dan,
another question need to be asked.
in the XML search , could i use the relative path to find the xml file?
i want to find the xml file from the same path where the exe file was placed.
for example:
i copy both the setup.exe and the xml file to drive E
then the xml search will search drive E
if both copied to D:\test
then the xml search will search D:\test
owe911
Any help is appreciate~ :D
Yes, you can use relative path.
As you noticed in my sample project, I'm using the following path for the .XML file:
where APPDIR is the installation folder selected by the user during the installation.
