dornseiffer
Problem with digital signature
We are using Advanced Installer 11.3 on Windows 7.
We decided to sign some of our files using the Installer.
For this purpose we created a certificate that has been stored in the "Trusted Root Certification Authorities" folder of the Microsoft Certificate Management tool.
We also created another certificate that we will use to sign our files, this one has been stored in the "Trusted Publisher" of the above tool.
So, we didn't request a certificate from an official authority.
To sign the files, we use an external tools, SignTool.exe, and that choice is specified in the Options / External Tools dialog.
Below you can see the Digital Signature page and the options used:
The build of the packages worked correctly.
But if we take a look at the digital signature of one of the files, displaying the certificate of it, we see the following:
The question is: is it mandatory to buy a certificate published by a Certificate Authority ?
Thanks for your help.
Re: Problem with digital signature
Indeed, you need to purchase a certificate published by a Certificate Authority.
Please note that a digital signature is used to help authenticate the identity of the creator of digital information. Digital signatures are based on digital certificates. Digital certificates are verifiers of identity issued by a trusted third party, which is known as a certification authority (CA). Digital signatures help establish the following authentication measures:
  • Authenticity
  • Integrity
  • Non-repudiation
The Digital Signature feature from Advanced Installer allows you digitally sign your installation package. By digitally signing your installers and products in Advanced Installer, you will increase your user's confidence in you and your company, giving them peace of mind about your software.
Please take a look on the Digital Signature article which may be useful to you.
