edgsoccer
How to change the colors on the surface theme
Is there a way to change the color on the Surface theme? i was able to change some by changing the images but i cant change the top bar color. :?:
Re: How to change the colors on the surface theme
The frame is split in parts. A predefined property and a image is associated with every part. A part is identified by the associated property.
In the Images Tab from the Themes page you can specify custom images that can be displayed on the dialogs or controls. A preview of an image is showed in the lower pane if that image is selected in the list.
You can also take a look on the Installation user interface frame customization article which may be useful to you.
If you have other questions, please let me know.
edgsoccer
I cannot find which image replaces the top bar color.
top bar
top bar
Have you tried changing the frame_caption.bmp image from the resources folder of Advanced Installer? E.g. the default path is:
C:\Program Files (x86)\Caphyon\Advanced Installer 12.0\themes\common-res\frame\metrolime
In the Images Tab you specify custom images that can be displayed on the dialogs. A preview of an image is showed in the lower pane if that image is selected in the list.
edgsoccer
ok that worked, i changed every image and the only part that im having problem with now is the edith path showed on the attached picture.. cant figure where to change that image. thanks
still green
still green
We apologize for our delayed reply.
Please take a look on our "How do I change this color?" thread which should lead you to the desired result.
edgsoccer
is that the same to change the gray on the license agreement window?
license agreement window.JPG (10.03 KiB) Viewed 8253 times
Are you changing the theme colour as well? If not, you should not change the gray colour. Instead, change the EULA text colour in a text editor (e.g. wordpad).
