almirmesic
Delete folder NOT generated by the installer
I have a cache folder generated by the application under "AppData/MyProgram....".
I was wondering how I can delete this folder when I do an uninstall (not by an upgrade)?
I've tried this but no luck: http://www.advancedinstaller.com/user-g ... older.html
See attached picture!
Almir
Screen Shot 2015-05-13 at 10.31.14.png (216.74 KiB) Viewed 4258 times
Irina
Re: Delete folder NOT generated by the installer
Hello and welcome to Advanced Installer forums!
In order to delete a folder for which you already know the location, it is not necessary to use a custom action.
For this, you can use the Uninstall Cleanup wizard feature to remove any redundant files or folder. On the Files and Folders page, simply right click the folder that needs to be cleaned up upon uninstall and click Uninstall Cleanup. The “Wizard” will guide you through the rest of the process.
If you need any help, please let us know.
Kind regards,
Irina
Ecaterina Irina Grosu - Advanced Installer Team
almirmesic
But can I delete a folder that is not generated by the installer?
Irina
Yes, the prior recommendation is applicable to a folder that is not created by the installer, but for which you know the location.
You will have to create the tree structure of the folder in Files and Folders page, and then make the described settings.
Do not hesitate to ask further questions.
Kind regards,
Irina
