BCh
The file xxx is not marked for installation - again
Using Advanced Installer 12.0. Installing on windows 7 64 bit.
Trying to create an install that is 32 and 64 bit compliant. Also trying to execute a custom action at end of install.
Have had problems before and solution was to create an exe install and not msi.
Believe I have done that now but still getting message that "file 'xxx' is not marked for installation" and the install fails.
Have attached aip and log file.
Brian
DuluxAUD.log
(310.93 KiB) Downloaded 532 times
DuluxAUD.aip
(35.58 KiB) Downloaded 461 times
Re: The file xxx is not marked for installation - again
Hi Brian,
Indeed, the DuluxReIndex.exe is not marked for installation, as you can see in the log:
MSI (s) (10:48) [21:14:42:617]: Product: DuluxAutoSolv -- Error 2753. The File 'DuluxReIndex.exe' is not marked for installation.
Also, the condition for the DuluxReIndex.exe's component is:
NOT VersionNT64
That means the component should be installed only on a 32-bit system.
However, in the log I can see that the VersionNT64 is set. That means you are running on a 64bit OS, a Windows 7 64bit.
In this case, you should make sure that the related custom action is only running on the X86 OSs.
You can also take a look on the How do I install resources based on the Operating System version? article which may be useful to you.
BCh
Thanks for reply.
Have got further but still issues.
I assume the reason the program was not marked for installation was that it was not defined in the Package Definition | Features and Components tab?
I did this and now am getting a Transforming table error when the install is trying to execute a custom action program.
This is causing the install to fail with the log showing a Transforming table error.
Have read other Transforming table errors in forum and others don't seem to match my issue which fails the install.
What is a transforming error and how come custom action execution is not running - I can run the program manually after the install.
Brian
DuluxAUD.log
Log showing Transforming Table error
(379.68 KiB) Downloaded 467 times
DuluxAUD.aip
Updated install program
(39.37 KiB) Downloaded 421 times
