mond007
Network error installing to Program Files
Hi, (I am a newbie)
I have written an elaborate application along with its install using Installshield 2010 Premier and everything is fine when installing on a standard PC but when I install on to a network the "C:\Program Files (x86)" directory is not where my files end up. ?? I need some help understanding where the file eventually gets installed on a network.
So here is the circumstances.
I have used the following link as a reference point but was unable to find a "Network" version of the "ProgramFilesFolder"
Either that or I am not understanding how Networks install files in areas.
The following is the Installshield Option on where to install files and I believe I have this correct.
The following image show that on a stand alone PC this install perfectly file and the application files the XML Data file is supposed to.
As you can see from the following image I can not see an option for a network version of "C:\Program Files (x86)" !!
Finally, I mean that I have a Setup.exe and I take it to the organisation and double click in order to install the software. Once install it is clearly looking for the MyData.XML in the following installed directory but fails :
N:\blah somewhere on the network\Company Solutions Ltd\Specific Product Name\MyData.XML
On a standalone PC it would be the following directory :
C:\Program Files (x86)\Company Solutions Ltd\Specific Product Name\MyData.XML
Installshield, "in the case of a Network", clearly is not installing to a place known as "ProgramFileFolder" somehow.
This is where I am at a loss. Any advise would be appreciate... Thanks in Advance.
Irina
Re: Network error installing to Program Files
Hello and welcome to Advanced Installer forum!
Having in sight the fact that you are using InstallShield tool, we are unable to help you.
What you should do is send your questions to the ISH support team instead.
Kind regards,
Irina
Ecaterina Irina Grosu - Advanced Installer Team
