a.guelle
[solved] Registry Subkey not shown in search
Hi Folks,
I am trying to get the path of a Java JDK installation from the registry to set the JAVA_HOME environment variable. The JDK is 64Bit and I checked "Search the 64-bit porion of the registry". The correct 64bit tree was chosen however the Key Selecter does not go beyond a specific key
HKEY_LOCAL_MACHINE\SOFTWARE\JavaSoft\Java Development Kit
Though there is a subkey
HKEY_LOCAL_MACHINE\SOFTWARE\JavaSoft\Java Development Kit\1.7
Even putting the registry path by hand does not produce a result when running the test.
So how can I get the value of
HKEY_LOCAL_MACHINE\SOFTWARE\JavaSoft\Java Development Kit\1.7\
"JavaHome"
Re: Registry Subkey not shown in search
Indeed, the registry picker does not display all keys. A fix will be available in a future version of Advanced Installer, thank you for bringing it to our attention.
However, adding manually the path in the Registry Location Properties fixed the problem. Please take a look on the bellow image and make sure you have the same settings:
JavaHome - SearchResult.png (25.42 KiB) Viewed 7482 times
a.guelle
Hi Dan,
thank you for our reply. The manual search works but returns a wrong value. I guess your search is also wrong. Searching the 64bit tree should NOT give a value in the folder:
C:\Program Files (x86)\
Cheers, Angelo
This is the Windows Installer normal behavior.
For details you can take a look on the Search Registry does not return Raw Value and copy file path force x86 threads which debate a similar problem.
a.guelle
Hey Dan,
both solutions do not work for me. Seems I will just have to script my desired behaviour on my own (And am again not able to use the Advanced Installer inbound feature).
Thanks so far,
Angelo
a.guelle
So for everyone who is interested, here is the solution:
Set a new property on the "Install Parameters" page. (In my case JAVA_HOME_PROP)
Create a custom "Execute inline script code" action (http://www.advancedinstaller.com/user-g ... ipt-inline) that fetches the registry key and sets the value to your newly created property. Make sure to set the Execution Time to "Immediately" and run it as 64-Bit script.
Set wso = CreateObject("Wscript.Shell")
Dim java_home
java_home = wso.RegRead("HKEY_LOCAL_MACHINE\SOFTWARE\JavaSoft\Java Development Kit\1.7\JavaHome")
Session.Property("JAVA_HOME_PROP") = java_home
Add a new Environment Variable "JAVA_HOME" on the "Environment" page and set [JAVA_HOME_PROP] as value.
Re: [solved] Registry Subkey not shown in search
This was fixed in version 14.3 of Advanced Installer released on September 18th, 2017.
