osherk
Web is installed even if the component it is not chosen
I have an unsolved issue.
I divided my application into 3 components:
web, services and db scripts.
when I run the exe I noticed that when I choose only DB Scripts, in addition to the DB Scripts, the web is also installed. I don't know why. I added screenshots.
Should I add conditions in the IIS settings? Dividing into components is not enough?
The services are not installed unless I chose them specifically in the ConfigureDlg. I don't have any special conditions there.
any idea? thanks!!!
files and folders.png (43.21 KiB) Viewed 2406 times
osherk
Re: Web is installed even if the component it is not chosen
Solved with adding conditions in the IIS settings, thanks
