NovaES
Failed to change the version number in the installer
I made several re-build to see if the program is running but does not run me. I tried to change the version number of the installer and tells me this error.
Solution?
Re: Failed to change the version number in the installer
Indeed, Windows Installer uses only the first three fields of the product version. If you include a fourth field in your product version, the installer ignores the fourth field. You can take a look on the ProductVersion property article.
Since you are only changing the fourth field, you can try the approach discussed in the following Automatic uninstall before installing new version forum thread in order to enable the major upgrades. A major upgrade is essentially the removal of an older product which is replaced by a newer product.
Basically, the upgrade process performs the following actions:
  • -Detect and completely remove older products.
    -Install the new product.
