swillia29
TeamCity plugin ability to update properties
With the team city plugin it would be nice to be able to set values to properties and set values to custom properties. I'm currently using the command line runner in order to do this. e.g
"C:\Program Files (x86)\Caphyon\Advanced Installer 11.8\bin\x86\AdvancedInstaller.com" /edit "C:\Advanced Installer Projects\<productname>\<version>\<productname>.aip" /SetVersion %build.number.short%
Re: TeamCity plugin ability to update properties
Thank you for your suggestion. I have added this improvement on our TODO list and it will be available in a future version of Advanced Installer.
This feature has been added in version 12.2 of Advanced Installer released on June 10th, 2015.
swillia29
HI,
I just tried to use the team city plugin and there is no option to set build number or set values to custom properties. I do see in your reply you say AdvancedInstaller 12.1 but I'm talking about the plugin that is on TeamCity. Not the application you install on Windows.
This should be doable using our "Command" section available for our TeamCity plugin. In this section you can use any command line (e.g. SetVersion) accepted by our application. However, due to a current issue in our TeamCity plugin passing command line parameters to our application doesn't work. A fix will be available in a future version of Advanced Installer. We will notify you when the fix will be out.
Until then, as a workaround, you can use a workaround as it is exposed in our "Setting version number for Control Panel" thread.
This is a follow up to my last reply. In what regards the command line issue of our TeamCity plugin, after further debating this with our development team it seems the command lines you add in the "Commands" section will take effect and modify the AIP (project file) settings as long as you use the Save command as the final line.
So, you should just use a file of commands like this:
SetVersion 6.0.5
Save
Return to “Feature Requests”
