tomas.maruska
Taskbar icon while uninstalling for 'Add or remove programs'
I've noticed that when I'm uninstalling my application from 'Add or remove programs' it has different taskbar icon (same as windows file explorer) then when I'm installing application.
Please, find attached two screenshots - first one from installation process, and second one from uninstallation.
Is there any way to fix it?
Tomas Maruska
Re: Taskbar icon while uninstalling for 'Add or remove progr
Hi Tomas,
I tested the scenario, but I couldn't reproduce the behavior. Can you reproduce it on multiple clean machines?
If so, can you please tell us the version of Advanced Installer and the Operating System you have on your machine and also a step by step test case scenario, so we can try to reproduce and investigate the problem?
tomas.maruska
Hi Eusebiu,
Please, find attached very simple project on which I was able to reproduce problem. You can also download builded setup here.
Testing OS was Windows 7 x86, but I saw similar behavior on different OS.
We use Advanced Installer v11.6.3
I think that key is run 'Modify' from 'Add and remove programs'. When I execute setup file, taskbar icon is OK.
Tomas Maruska
project.zip
(3.55 KiB) Downloaded 554 times
Hi Tomas,
Sorry for the delayed reply.
I tested your package and, indeed, I was able to reproduce the problem. We will investigate the problem to see if it is an Advanced Installer issue. If so, we will fix it in a future version of Advanced Installer. Thank you for bringing it to our attention.
tomas.maruska
Thanks for your help. Please, keep me in touch if you find something new.
Best Regards,
Tomas Maruska
You're welcome Tomas.
I'll let you know when the issue is fixed.
tomas.maruska
Re: Taskbar icon while uninstalling for 'Add or remove programs'
For the record, I was able to fix this problem by turning Enhaced UI to 'Always (uninstall, install, maintenance)' in Themes -> Settings (tab)
Hope this helps somebody.
Tomas Maruska
Thank you for the tip Tomas. I'm sure this will help other users with the same problem.
