naftaly
Error while creating a scheduled task
On windows 10 we just started having a problem with installing scheduled tasks. This seems to work fine with other versions of windows. Here's a screenshot of the error.
Error dialog
Error dialog
Palette Master 1.3.1_installer_error_installingXRD_Windows 10 Preview.png (6.99 KiB) Viewed 3500 times
If we hit ignore the installer continues and finishes fine, software also seems to be fine. Any ideas what might be going on. I've also attached the verbose log of the installer.
thx,
Alex
log.txt
Verbose Error log
(541.73 KiB) Downloaded 267 times
mihai.petcu
Re: Error while creating a scheduled task
Can you replicate this with any new test project? If not, can you send us the .AIP so we can investigate it?
Please keep in mind that Advanced Installer is not yet Windows 10 compatible. Efforts in this direction have been very slight until a stable release is available from Microsoft. However, we appreciate the feedback and noted this behavior to consider for the future.
naftaly
Hi, I have not tried to replicate it in a small project but I will. In the meantime, i've attached the aip in case you get a chance to look at it and see if there is anything immediately obvious. Just as a side note, this installer has been good to us for a while now without any issues so it might just be a compatibility issue with win 10. thx in advance for any help. much appreciated.
regards,
Alex
xrdd.aip.zip
AIP file showing the issue
(13.52 KiB) Downloaded 264 times
First of all we apologize for our delayed answer. We had a release yesterday and we were quite busy lately.
I've tested your installation scenario on a Windows 10 Preview machine, but the installation succeeded. Would it be possible for you to also test the setup installation on a clean Windows 10 machine? For testing purposes we always recommend to be used virtual machines with clean states so that when something goes wrong you can easily revert to a clean state of the virtual machine.
Also, can you send us a download link for your setup to support at advancedinstaller dot com so we can test and investigate it on our side?
