a.guelle
[solved] Checking for empty Foder on "FolderDlg"
I wanted to check if the user provided an APPDIR path on the FolderDlg, so I added APPDIR as a condition to display the next dialog. But htis does not work...
Any ideas?
Angelo
Re: Checking for empty Foder on "FolderDlg"
Hi Angelo,
Please note that the Verify and set the selected folder path - SetTargetPath published event notifies the installer to check and set the selected path. If the path is not valid or the installer doesn't have write access for it, all control events associated with the control are blocked.
Also, the Installation Path Dialog allows you to select a validation method for the selected installation path. The actual validation is performed when pressing [ Next ] button.
As you can see, the user will not be able to proceed with the installation if an empty path is selected or the selected path does not pass the validation. So, can you please tell us why would you like to add an extra check?
a.guelle
Hi Dan,
my Installation Path -> Validation is set to "Use native Windows Installer validation" and the "Verify and set the selected folder Path" event is published. But I am able to provide an empty path and go on with the next dialog... That's something I wanna avoid. I already sent my *.aip file to the support mail address.
a.guelle
Is there a solution for my problem?
I assume you deleted the path from the FolderDlg field, right? So, you got an empty path as the installation path?
Please note that the property APPDIR was not actually changed. Its value will be the default one, e.g. C:\Program Files (x86)\Your Company\Your Application\.
You can check this by yourself, using the following test case:
1) set the folder path to an empty string
2) go in the next/previous dialog
3) return to the FolderDlg dialog
Notice that the installation path is filled to the default path.
The path of the installation is actually changed when the Browse... functionality is triggered.
a.guelle
Hi Dan,
you are right, this seems to work.
Thanx,
Angelo
You're always welcome Angelo,
