osherk
No dependency between 2 servers to install...
In my application there are 2 servers that the user can choose rather to install or not.
I need a dependency between them. The user will see only the master service in the custom dialog:
If he will check it - both of the servers (master and slave) will be installed.
If not - neither of them will be installed.
I configured as in the screenshots below and if I check the master server in the custom dialog, it is the only server to be installed. The slave server is not installed at all.
Am I wrong with my settings?
Thanks!
mihai.petcu
Re: No dependency between 2 servers to install...
You can move "DMS" to be a child feature to "State Server", then enable "Use parent feature installation settings" option.
