a.guelle
[solved] Prerequisite Condition does not find Registry Path
I have to mandatory install the "SQL Server Command Line Tools" as a prerequisite. But the registry key is not shown by the RegKey Picker and is never found either. The option "Use 64-bit locations when evaluating conditions on a 64-bit machine" does not make a change either.
The desired value to get is:
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Microsoft SQL Server\SqlCmdLnUtils\CurrentVersion]
"Version"="11.2.5058.0"
mihai.petcu
Re: Prerequisite Condition does not find Registry Path
OK so the registry value is in the 64-bit portion of the registry. Can you find it with regedit?
Keep in mind that in the "New Search" dialog you should have something like:
HKLM\Software\Microsoft\Microsoft SQL Server\SqlCmdLnUtils\CurrentVersion
Does it work if you don't use the picker and just copy-paste the above in the "Registry value" field?
P.S. I can't see the attached image. Did you forget to attach it?
a.guelle
Hi Mihai,
Yes, I can find the value with regedit. I can see the key ehn using the picker, but noth the values. Copying the path manually does not work. Evaluating returns FAILURE and the Installer does never find it.
By the way I attached the last picture properly as I could see it in the preview.
a.guelle
Just got the solution from a colleague.
It works if I put in the reg value by hand. I just missed the Value at the end of the string:
Wrong search...
corrected Search...
HKLM\SOFTWARE\Microsoft\Microsoft SQL Server\SqlCmdLnUtils\CurrentVersion\Version
