andreas_huber69
5x5 letter serial number does not fit on page
See subject and attachment. Our serial number has exactly the same format as the ones used by Microsoft.
How can we modify the dialog such that the last edit box is not cut off?
We're using Advanced Installer Professional 12.2.
Thanks!
mihai.petcu
Re: 5x5 letter serial number does not fit on page
Hi Andreas and welcome to Advanced Installer forums,
Since the Dialog Editor is available starting with the Enterprise edition, you should open the following file in a text file editor:
C:\Program Files (x86)\Caphyon\Advanced Installer 12.2\themes\classic\fragments\UserRegistrationDlg.aip
... find the PIDKEY masked edit control row and edit its width.
andreas_huber69
Hi Mihai
Thanks for your answer. Your suggestion fixes our problem.
Would it be possible to have this fixed in a future version of Advanced Installer as well? I think it is reasonable to expect that the standard dialog should be wide enough for a MS-style serial.
Thanks & Regards,
Andreas
mihai.petcu
You're welcome Andreas and absolutely, the default value will be updated in the next release. Thank you for the heads-up.
