gilse
Unclear Updater Error - "Checking for updates - The directory name is invalid"
My product updater displays unclear error.
It says : "Checking for updates - The directory name is invalid".
I performed the following checks:
1. I checked my updates server and the file is available for download (I pasted the URL in IE and it suggested to download the file).
2. The *.aiu file was also properly downloaded to a client workstation from the updates server.
If I delete an *.aiu file it is downloaded again when I try to update.
3. The *.aiu file contains correct values.
4. Updater INI file also contains correct folder values and correct update server URI.
My product is 64 bit application located under "C:\Program Files\COMPANY_NAME\PRODUCT_NAME\Client" folder in 64 bit Windows 7 Professional workstation.
What should I do next?...
Please help!
Best Regards,
Gil
Re: Unclear Updater Error - "Checking for updates - The directory name is invalid"
Hi Gil and welcome to Advanced Installer forums,
I'm not sure why you encountered this behaviour.
In order to further investigate this, please send us the .AIP(project file) of the old installation package, the .AIP(project file) of the upgraded version and the Updates configuration project to support at advancedinstaller dot com. If it contains confidential information you can send us a small test project which reproduce this behavior.
