NovaES
Update package without deleting some files.
Before I begin, I want to explain that I do a little.
When launching full package updates (silently without interface) not as I cleared with online documentation on how to create specific patches, would do recompiling the whole package ...
Well, if you find that is the installed version, I do not want to remove certain files or replace them just to leave them intact as they are files of personal settings and get an update to replace certain files would be chaos for the user to reconfigure all .
I would appreciate help me with images and do not understand their documentation online.
I must point out to you that when gender compile an .exe and .msi no
Also, that this package can be installed, you must see a minimum number of installed version so that it can be installed, if the number is not from 4.xx not let be installed if fewer
Thanks, I hope your answers
Re: Update package without deleting some files.
To achieve what you want (update files without being first removed all files and then installed the new ones - this is how a major upgrade works) you can create your updated product installation as patches. For this please carefully follow our "Authoring a Windows Installer patch" tutorial steps. Also, because creating patches is a very delicate and sensitive process please make sure all the patch creation rules will be fulfilled.
If you are building an EXE setup package you can still create patches by extracting the embedded MSI from the EXE setup. Just use the /extract EXE proprietary command line to extract the MSI.
I'm afraid I don't fully understand this. Can you please give us more details about what you are trying to achieve (maybe exemplify a bit)?
NovaES
I'm following in the footsteps of http://www.advancedinstaller.com/user-g ... patch.html
I want to indicate that I do not hear very well. To create an image I need to have an .msi but my project is created in an .exe
I just want to get a patch to try and tell you to do, whether to replace or delete or add new files that I specify.
Nor if the patch, I include all the main installer files. If you would kindly put some images to clarify me around with this I would appreciate it.
NovaES
I want to create is an update package, which tells you replace or add files. Just that.
NovaES
help me please
If you are building your setups as EXE packages, then in order to create a patch you will have to first extract the embedded MSI from the EXE setup. Just use the /extract EXE proprietary command line to extract the MSI like this:
setup.exe /extract <path_to_msi>
Then, just use the extracted MSIs to create a patch as described in our "Authoring a Windows Installer patch" tutorial.
