andy_222
Problem with Repacker on HyperV VM
Hello
I try to repack an Application following this Tutorial
http://www.advancedinstaller.com/user-g ... kager.html
But I recive allways the error
Error during virtual machine configuration: shared Folders
I use a HyperV VM on a Windows 8.1 Computer. I have installed Advance installer 21.2.1
Have I create also some Folders on the VM?
Andy
Re: Problem with Repacker on HyperV VM
Hello Andy and welcome to our forums,
I apologize for my delayed reply. I tested the scenario but the repackage operation on a Hyper-V VM was successful. Can you please tell us if you installed Advanced Installer on your Windows 8.1 computer (which actually hosts the Hyper-V VM) or did you install Advanced Installer on the Hyper-V VM?
If AI is installed on your real machine and you want to perform the repackaging operation on your Hyper-V VM, then you should follow our "Repackaging an existing installation in a Hyper-V virtual machine" tutorial steps. Also, please check our "Repackaging in VMs" article and make sure all the requirements are fulfilled by your system.
If AI is installed on your Hyper-V VM, then you should follow the "Repackaging an existing installation" tutorial.
Let us know if this helped, otherwise please give us more details about the software configuration of your system (Windows version, architecture, system language for both real machine and VM).
andy_222
Hello Daniel
I use Windows 8.1 Ent as the Host OS. The VM is installed as Windows 8.1 Pro.
Both Systems are x64.
The Host Language is en-US, the Guest Language is de-CH
The VHDx and the VM Config are stored on D:\Virtual Machines
AI is installed on the Host System
I follow this Guide "Repackaging an existing installation in a Hyper-V virtual machine" without success.
What I can see is that i have never connected a virtual CD/DVD drive "Advanced Repackager" in the Guest OS
I think the AI cannot create the ISO for the Guest OS. I have also nonsuccess when I run the AI as Administrator.
Kind regards
Andy
Hello Andy,
Can you please make sure the "Integration Services" are enabled on the guest virtual machine? The "Data Exchange" and "Heartbeat" services are especially important. Please power off your Hyper-V VM, make sure the above services are enabled, power on the VM and try again the repackaging operation.
If this still doesn't help you please send us an email to support at advancedinstaller dot com so we can forward you a debug version of our "Repackager" tool to try further troubleshooting this.
andy_222
Hi Daniel
The Integration Services are enable. I will send you an Email
Andy
Hello Andy,
I sent you by email a download link for a debug version of AI. Please send us the Repackager log (as advised in my email) to support at advancedinstaller dot com so we can investigate.
This was fixed in version 13.8 of Advanced Installer released on March 30th, 2017.
