elou
Optional Panel after SetupTypDlg is not correctly displayed
I have a Dialog which I wants to be optional, depending on if a feature have to be installed or not.
I have create a new Dialog and use the "show only if...." option to make it optional.
The dialog will not correctly appear, I have to select the feature, go back, and select "standard installaton" to open it.
I have added a project file which demonstrate this.
regards, Éric.
FeatureImmediate.aip
(15.38 KiB) Downloaded 372 times
Re: Optional Panel after SetupTypDlg is not correctly displayed
This happens because by default your feature is configured not to be installed. Therefore the following condition:
(&Funktion = 3) AND NOT (!Funktion = 3)
set on the control event (added on [Standard] button from "SetupTypeDlg" dialog), which sets the "OptionalDialog_Cond" property to "1", will be evaluated to FALSE.
So, can you please go to "Organization" page, select your "OptionalFeature" and set its "Installation Behavior" to "Installed" by default and then test again the installation?
elou
Hello Daniel,
thanks for your reply.
Setting the installation behaviour to "Installed" do not solve the problem and is not an option for me.
The condition
is absolutly correct because I want to display the OptionalDialog when the feature has been selected for installation.
It seams that at the point where the condition is being tested ("do the OptionalDialog have to be shown or not?"), the "feature variable" have not the correct value.
It also seams to me that the "OptionalDialog_Cond" is missing when the InstallMode is InstallModeCustom or InstallModeComplete.
Éric.
Hello Éric,
Please note that your feature is selected to "Not Installed" by default and I don't see and control event on your dialogs which could change the installation state of the feature. Therefore the related condition will be always false.
Can you please give us more details (maybe iterate a detailed test case) about the behavior you are trying to achieve?
elou
Hello Daniel,
thanks for your reply, please see the workflow I expect as attachment, hope you'll appreciate my artwork :)
regards, Éric.
Hello Éric,
To accomplish this you should proceed as follows:
1. go to "Dialogs" page and expand the "SetupTypeDlg" dialog tree
2. delete the "OptionalDialog_Cond"
3. expand the "InstallMode=InstallModeCustom" folder tree
4. select the "CustomizeDlg" in the expanded list and and from its context menu use "New Dialog" option to add a new dialog
5. select the new added dialog and from its context menu choose "Show only if..." option and use the following condition:
((&Funktion = 3) AND NOT (!Funktion = 3))
6. rebuild and test again the installation
elou
Hello Daniel,
Ok, it solves my problem, but do please notice:
- I do not want to create a new Dialog, so I have used my CustomizeBlg by moving it per drag&drop
- The result produced by the "Show only if..." wizzard for a component placed after SetupTypeDlg is not the expected one, this is an issue!
regards,
Éric.
Hello Éric,
Please give us a test case or a more detailed description of the issue so we can be able to investigate this.
elou
When wo choose
"Show ony if..."
on the
OptionalDialog
Then it will be added before
InstallMore=InstallModeCustom
which is wrong.
It shoud have been added at least in
Éric
Hello Éric,
Thank you for your feedback. Indeed, currently this seems to be a limitation in our application. We'll try to add an improvement in a future version of Advanced Installer. Thank you for your suggestion.
