Ruben
Optionally Browse for a Folder
Hi Team and Community,
We need to user to optionally select an existing folder -- just to read data from.
Following this guide http://www.advancedinstaller.com/user-g ... older.html, we successfully added a folder selection dialog.
That works well but the path selection is not optional, sadly. The user is forced to select an existing, valid folder.
We consider a special initial value like "(nothing selected)" or "No, I don't want to import data" in the path edit field.
Is there a user friendly solution to make the folder selection optional ?
Thank you,
Ruben
Re: Optionally Browse for a Folder
Hi Ruben,
I'm afraid that you need a valid path for the Path Edit control.
However, you can use Control Condition to hide or show the related controls (e.g. pathedit and the browse button). Please see the attached sample .AIP that implement this scenario.
SampleProject.zip
(3.25 KiB) Downloaded 335 times
Ruben
Hello Dan,
Building the SampleProject failed with a missing resource.
My machine has the folder C:\Dokumente und Einstellungen\All Users\Anwendungsdaten\Caphyon\Advanced Installer, but with only a zero-byte file "Settings.ais" inside and nothing else.
Do you know a way to fix it ?
Thank you,
Ruben
Resources referred by the project are missing.
C:\Dokumente und Einstellungen\All Users\Anwendungsdaten\Caphyon\Advanced Installer\Repository\dictionaries\ui_en.ail
Advanced Installer 12.2.1 build 64247
*** Stack Trace (x86) ***
[0x7c812aeb]  RaiseException()
[0x78ac872d]  CxxThrowException()
[0x017e108d]  std::_Init_locks::operator=()
[0x774cf354]  CoInitializeEx()
[0x774cd6cc]  IsValidInterface()
[0x774cd1ef]  CoTaskMemAlloc()
[0x774cd8b5]  IsValidInterface()
[0x01010da3]  -----
[0x78ab0350]  _set_flsgetvalue()
[0x01010f29]  -----
[0x00400000]  MODULE_BASE_ADDRESS
Hi Ruben,
In the Dictionaries tab from the Translations tab, please delete the <AI_REPOSITORY>dictionaries\ui_en.ail entry.
Let me know if there is anything else I can help you with.
Ruben
Thank you, Dan ! That works. For other readers, that's how it looks:
respectively:
The attachment Snippetx2.jpg is no longer available
You're always welcome Ruben,
