DiegoCP
Install Prerequisites silently
So basically there are some prerequisites needed to be installed in case the user doesn't have them but i need them to run silently.
Ex: Visual C++ Redistributable for Visual Studio 2013 x86.
Is this possible in anyway?? I want to make the installer practically automatic.
Thank You for your support.
Sincerely,
Diego.
Re: Install Prerequisites silently
Hi Diego,
In order to silently install a prerequisite you can add the corresponding command line switches in the Install Command Lines section from the Prerequisite Setup Files Tab.
Please note that the prerequisites from our predefined list contains the switches for silent installation. e.g. for Visual C++ Redistributable for Visual Studio 2013 x86
DiegoCP
Hello Dan,
Thank You. Thats exactly what i need! :)
Sincerely,
Diego.
You're always welcome Diego,
If you have any other questions, please do not hesitate to contact us.
