aeplengg
Setup installation error
Hi Advanced Installer,
I am getting the error: Operation failed for setup installation.
I have used Advanced Installer 11.4.1 to create this setup.
I installed this setup on many computers but found no error. But one of my computer(W7, Pro) prompt this warning.
For your reference: my setup contains USB-Driver as pre-requisite, registry keys.
How can I find more information, what is causing the problem here?
Swati
AI Setup error.png (53.58 KiB) Viewed 8112 times
Re: Setup installation error
Hi Swati,
The information in a verbose log can be helpful when trying to troubleshoot Windows Installer package deployment.
You can take a look on the Windows Installer Best Practices – verbose logging article and How Do I Read a Windows Installer Verbose Log File? article which may be useful to you.
aeplengg
Hello
While installing setup, we got one error saying '.... stopped working' (attached screen shot for your reference)
Unfortunately my 'enable verbose log' option was not enable in .aip.
What is the cause?
Regards
Swati
Setup installation error.png (81.83 KiB) Viewed 7487 times
Hello Swati,
When you get similar errors, please send us the Stack Trace error so we can resimbolicate it.
Can you please tell us if the behaviour still persists? If Yes, in order to have a better view about this, can you please send us the .AIP (project file) and a verbose log of the installation process?
Here's the "Create a log" article:
http://www.advancedinstaller.com/user-guide/qa-log.html
aeplengg
Hello Dan
This behavior is not persistent.
But one of my client again faced this issue on window XP PC.
Snapshot and log is attached for your reference.
Regards
Swati
MSI57.LOG
(114.28 KiB) Downloaded 361 times
ADI Error.png (31.17 KiB) Viewed 7474 times
I'm afraid the sent log file doesn't contain any useful information. However, taking into consideration the first attached error message this looks similar with a recent bug we have just fixed. We had a similar random issue with the same error message (... has stopped working) triggered by a glitch in our "Service Failure Operation" support. A fix for this issue will be available in our next version (13.6) of Advanced Installer.
Can you let us know if you had defined any service control operation in your setup project (i.e. in "Services" page)?
aeplengg
Hello
Now I faced this issue frequently on my windows XP PC's with my ADI setup.
Note: The windows XP PC's which i am using is the one which i have installed this setup many times for testing. But few days back after uninstalling my setup, when i tried to install the same setup it gives this error("Windows cannot ....")
I have attached another PC verbose log for same error. Please check if this can be helpful to find the problem.
My .aip does not contain any services in it.
My ADI maintenance plan has expired. How and when this update will be available?
Regards
Swati
Install.log
(325.75 KiB) Downloaded 613 times
Hello Swati,
The last attached log file is from a successful installation. Can you please send us the following resources to support at advancedinstaller dot com so we can further test and investigate your scenario:
1. the AIP (project file)
2. a download link for your built setup package
3. a screenshot with the error you get frequently
4. a test case with the steps you perform before the error is thrown
Our next version should be released by the end of the next month. However, if your setup project doesn't contain any configured service failure operation, then I think the error is caused by another issue. Just send us the above requested resources so we further investigate them.
aeplengg
Hello
Please check mail dated 31st Jan, 2017 for this issue.
Please update us.
Regards
Swati
