karthick.k
Issue while using multiple instances
We have built an installer with multiple instances. We have added 2 instances (iRely & EOM), while trying to install with new instance, the installer is not responding.
We tried uninstalling the previous installed application, then the installer works fine.
2015-07-16 17_37_02.png (38.14 KiB) Viewed 6275 times
Please assist us.
I have attached the .aip file also.
Installer Project.zip
(83.11 KiB) Downloaded 275 times
Re: Issue while using multiple instances
I've tested your scenario but I cannot replicate it. Note that I've used dummy resources in order to build your project.
After installing the main instance, I was prompted to install the others. Please see below the entries from Programs and Features list:
Programs and Features List.png (12.88 KiB) Viewed 6215 times
By the way, if you need to upgrade your instances, then this scenario is not supported. We don't have support for per-instances major upgrades.
You can also take a look on the Multiple Instance upgrade not working properly forum thread which debates a similar subject.
karthick.k
Hi Dan,
Thank you for suggestion. However we will not upgrade any of this instances rather we are considering our new release will be treated a different product.
And we have noticed that multiple instances was working in some of system but not in others. Recently we got this problem in many for our customers, who are using Windows server 2008 R2 and Windows server 2012.
Even when we are getting this issue, we are not even getting the verbose log.
Please help us on troubleshooting this issue.
Thank you again :)
karthick.k
Hi Dan,
Did you get a chance to look at this?
Thank you.
We apologize for our delayed reply. In order to have a clear view of the installation scenario when this issue occurs, can you please iterate for us a detailed step by stet test case which we can follow to replicate the issue? Also if you could isolate the behavior in a buildable sample (AIP + its referenced files) and send it us alongside with a test case, this will be very useful for us too.
karthick.k
Hi Daniel,
Sorry for the delay in reply.
Here is the attachment with the scenarios.
Karthick
Muliple_Instance_issue.zip
(454.81 KiB) Downloaded 292 times
Hello Karthick,
I'm not sure why this happens. In order to be able to further investigate this we will need all resources (AIPs + their built setups) necessary to replicate the issue. So, please send a download link for them to us to support at advancedinstaller dot com so we can test and investigate this on our side?
Also, as I already mentioned, if you could isolate the behavior in a buildable sample (AIP + its referenced files) this will be even better.
The Major upgrades for multiple instances support has been added in version 12.7 of Advanced Installer released on February 4th, 2016.
