mheckmann
Setting a Default Program on Condition
my software comes with 2 executlables, a regular program and a "runtime" version. I would now like to let the user choose if the file type associated with my software should by defult be opened with the regular or with the runtime version.
Using the File Associations page I didn't succeed as I could not add the same extension to different ProgIds.
What would be the best course of action?
Thx
Markus
Re: Setting a Default Program on Condition
Hi Markus,
Please note that you can associate the extensions under the same ProgId with different executable files (see below image). Can you please tell us what versions of Advanced Installer are you using?
mheckmann
Hi Dan,
thank you very much. I completely missed that and always thought I could only specify the extension only ones. I'll try this out.
Using Advanced Installer 12.0 at the moment.
Thanks again
Markus
You're welcome Markus,
Yes, this option is available in the 12.0 version of Advanced Installer.
mheckmann
Hi DAn,
so after adding in the same file association to the ProgId, how can I let the user choose which Extension to use by default. One of the 2 extensions I can place in a seperate feature but the second extension I then can't, the option is greyed out and therefor there is no way to add an condition?
Markus
Hello Markus,
You would't have to place each extension in a separate feature (than its associated EXE). All you have to do is to make sure the EXEs to which each extension is associated are placed in separate component. Then, you should use complementary conditions on the component of each EXE. An extension is installed only if associated component (from "Organization" page) is installed.
Here is a straight-forward test case you can use:
1. go to "File Association" page select the first extension and from its context menu choose "Go To Component" option
2. in "Organization" page, on the selected component add a condition like this:
USER_PROP = <EXE1 selection>
3. repeat the first step for the second extension
4. in "Organization" page, on the selected component add a condition like this:
USER_PROP = <EXE2 selection>
5. rebuild and test the scenario
