karthick.k
Installer ending Prematurely
We have an issue, where the installer is ending prematurely. Here is the verbose log attached.
We don't see the issue in all the machines, but getting this in a particular machine which is Windows 7 .It seems like failing on 'AI_AiRemoveFilesImmediate' with return code as 1603.
Please help us on fixing this.
Re: Installer ending Prematurely
I don't see any log attached. Did you missed ? Also, can you please attach the .AIP(project file)? If it contains confidential information you can send us on email to support at advancedinstaller dot com with the log and the AIP.
Also, can you please tell us if the behaviour persists on a clean machine?
karthick.k
Hi Dan,
Sorry, I think I missed the verbose log. I am sending you the log and the project file in email.
Thank you.
karthick.k
Hi Dan,
Do we have any update on this?
My colleague Dan is out of the office this week so I'll continue this thread. Unfortunately, I didn't manage to identify your email in our Inbox. Did you sent the email to support at advancedinstaller dot com? If so, please let us know which is the subject of the email you sent. Maybe you can send the email again or a reply to it.
karthick.k
Yes, i have sent email to ''support@advancedinstaller.com'' with the subject as 'Installer ending Prematurely'.
Let me resend you the email again.
As of now I'm afraid we still didn't receive the email you mentioned. Can you please make sure the email is not somehow blocked by your email server? Also, can you try to send us the email from a public email address (e.g. gmail, yahoo, etc) so we can check if the email is received by our server?
Also, if you want (or are allowed) you can temporary post here your email address so we can try sending you a test email.
karthick.k
Hi Daniel,
Okay, let me know send it from my personal email.
Here is my offical email id: <deleted by moderator>
I've sent you an email with the following subject: "Test Email from AdvancedInstaller"
Let us know when you received it and after you reply back to us.
karthick.k
Hi Daniel,
I have received your email and reply back to you with project files.
We still didn't receive any email (reply back) from you. I've also checked the email logs with our email server administrator and I can confirm you that no email from you reached our part. Most probably there is a filter on your email server (applied on your side) which blocks your email (maybe the attachments are the cause). Can you please check this with your email server admin?
Also, in the meantime it is recommended to send us your email using an email address from a well known public provider (Gmail, Yahoo, etc).
karthick.k
Hi Daniel,
I have sent you the email with the link to download the project files.
Hope this should work ;)
Hello Karthick,
Yes, this time we received your email. I've sent you a reply over email.
karthick.k
We have the same issue again, Please assist us on resolving this asap.
Attached is the log file.
Thankyou
i21_15.4.1103.238.zip
(163.83 KiB) Downloaded 293 times
Hello Karthick,
Please send us the .aip (project file) to support at advancedinstaller dot com so we can investigate its settings and further test on our side.
