truettp
Icon Cache / Missing Shortcut Icons
After another program is installed, our shortcut icons are missing (from the %SystemRoot%/Installer/PRODUCT GUID/.exe folder).
Other application icons remain. Their shortcut icons correctly point to their app .exe. Why is our application (installed with Advanced Installer) pointing to the %SystemRoot%/Installer/PRODUCT GUID/.exe folder?
I have researched extensively and deleted and rebuilt the icon cache, etc., etc. to no avail. We just want our application shortcuts to point to our .exe and not the %SystemRoot% folder.
Re: Icon Cache / Missing Shortcut Icons
Please keep in mind that the icons are not cached by Advanced Installer in "%SystemRoot%\Installer\", but they are cached by Windows Installer at installation time. It seems somehow the cached (at install time) icon is lost. This behavior was also sporadically encountered by other users, but unfortunately we didn't find any resolution or explanation for this. This seems to be a Windows Installer malfunction.
Please take a look on "Desktop icon is not being shown properly" thread which debates a similar issue.
This is a follow up to my previous reply.
If you want the shortcut to point to your EXE app (its target file), then just make sure you don't explicitly specify an icon in the "Icon" field from the "Shortcut Properties" dialog. When the "Icon" field is left empty the shortcut will use by default its target file icon.
