Lersilva
Blank fields
After using the installer advance our system started showing blank screens , and to restart the machine to go back to work.
The problem arises again when they are using the program.
The following screen of our program and the installer
Caderp.aip
(92.48 KiB) Downloaded 336 times
Irina
Re: Blank fields
Unfortunately, we cannot reproduce the behavior.
Can you please tell me the steps you are making before obtaining the error? A more step by step use case will help us for further investigation.
Until then, we strongly recommend you to test the project on a clean machine (or even a virtual machine).
Kind regards,
Irina
Ecaterina Irina Grosu - Advanced Installer Team
