ima-aa
Dialog Editor and Custom Dialogs
I've got a question regarding a custom dialog.
Because its not possible to link a dialog in two stages (main install and repair) I created a copy of the dialog. Both should have the same controls and write the values to the registry.
The server simple edit has for a example a property called "SERVER_PROP". On both dialogs it has the same property - so its ok.
But I have also a checkbox with the property called "SSPI_PROP". Here it is not allowed to have the same property - on the second dialog the property is renamed to "SSPI_PROP_1".
Why is it possible to have the same property in simple edit but not in checkboxes?
greetings
Andreas
setup dialog.PNG (98.15 KiB) Viewed 5895 times
Irina
Re: Dialog Editor and Custom Dialogs
Hello Andreas,
The design does not permit for two checkboxes to have the same property.
A possible workaround is to set two "Set installer property" Published Events on the first checkbox (SSPI_PROP_1) like this:
  • -Property: SSPI_PROP_2, Argument : [SSPI_PROP_1], Condition: SSPI_PROP_1
    -Property: SSPI_PROP_2, Argument : {}, Condition: not SSPI_PROP_1
If you have more questions, do not hesitate to ask.
Kind regards,
Irina
Ecaterina Irina Grosu - Advanced Installer Team
Return to “Feature Requests”
