prasadus92
Can a mixed package installer upgrades a old 32-bit installer?
Earlier, I had an installer of package type 32-bit. Now due to some requirement, my installer needs to copy separate DLLs depending on some other application's bitness. I am thinking to change my installer's package type as "mixed 32/64-bit matching the platform". But with this change, whether my new installer (mixed package) will upgrade the older one without any problem? Is this the right way of doing it? Please help.
Prasad
Irina
Re: Can a mixed package installer upgrades a old 32-bit installer?
Hello Prasad,
Yes, there should be no problem.
Even if your previous version is a 32 - bit installer and your new version is a mixed installer, the update will be made accordingly.
Do not hesitate to ask if you have further questions.
Kind regards,
irina
Ecaterina Irina Grosu - Advanced Installer Team
