NovaES
[HELP] Change language routine and add a screen
Hello, today I come to ask two things
1) I have in my language installer with several sentences changed. I wonder how I can change that path where language stores information that I have changed, because when formatting is lost and have to go back and change those phrases I like to save it with my installer.
2) When my installer to run, I wonder how I can add a screen as intro for about 20 seconds and after that start the installer. Keeping in mind that when you go to make an update commands, this screen does not appear.
Thank You
mihai.petcu
Re: [HELP] Change language routine and add a screen
1) The steps on how to work with and save project strings are in the Project Strings Tab article.
2) You can develop a custom action that shows a splash screen and schedule it before "Wizard Dialogs Stage" -> "PrepareDlg" standard action. If you don't want it to be shown during an upgrade simply set its condition to:
OLDPRODUCTS
NovaES
Hello, when I try to move my dictionary tells me it edited.
What I want to do is move the route of language that I edited to another route.
mihai.petcu
As the error indicates you cannot move the contents of the repository if the current loaded project refers fragments from it.
- if you want to perform the change from the Advanced Installer GUI open another project that doesn't use the strings
- otherwise you can do it manually by browsing to the repository location in Windows Explorer
NovaES
Hi thanks for answering.
What I want is to move the language manually edited and saved default on that route.
What I have to do is close advancedinstaller and move the files edited and re-load?
I guess it's that tab edited the chain where it is stored
Thank you
NovaES
Help me please
