Rorschach
What does "Sync Status" mean in Assembly Properties
Hello
What does "Sync Status" mean in Assembly Properties?
By default it will only check Name attribute. So does it mean that during installing the installer will only check the assembly by name? And if installer find there is already one assembly with the same name exist in GAC, it will not install the one in installer even if the version is newer (version is Unsync Status)?
Re: What does "Sync Status" mean in Assembly Properties
During the Build process, the assembly attributes(e.g. Name, Culture, Version etc) are synced if the corresponding checkbox is enabled. So, if your assembly is in development process, you can sync the related attributes since they will most likely change during the development process.
Please note this is related to the build process of the installer. It does not affect the behaviour during installation.
