Russell
File came from another computer and might be blocked.
On a Windows 2008 server machine I was unable to run my installed application after installation. On investigation I discovered that the file was blocked because "it came from another computer" (see attachment). I needed to unblock it manually and then it all worked fine.
I am using a signed installation to deploy a .NET Winforms executable project. Is there something I need to change in my installation project to prevent this from happening?
Thanks for your assistance.
Russell.
Re: File came from another computer and might be blocked.
Hello Russell,
I'm not totally sure but this shouldn't happen if you digitally signed your installation files. Can you please make sure your application file is added in our "Digital Signature" page -> "Files Configured for Signing" section and rebuild the project with the "Enable signing" option from the same page enabled.
Also, please make sure your digital signature certificate is recognized on the related computer.
