liuyt1
how to change default install path
hi,
In "Files and Folders", I create few folder and file which means default install path (like c:\program files\myapp\...)
Ideally, in "FolderDlg", if user change default install path (c:\program files\myapp\...) to different value like "c:\myapp", then these files should be install to "c:\myapp".
But I saw all these files always go to "c:\program files\myapp".
Any idea for this issue?
YT
Re: how to change default install path
The path of the Application Folder is displayed on the FolderDlg, so you can add your files/folders under this folder. This is usually the main installation folder.
If the behaviour still persists, please send us the .AIP (project file) to support at advancedinstaller dot com so we can investigate it? If it contains confidential information you can send us a small test project which reproduce this behaviour.
liuyt1
Dan,
I tried again, but not working.
I try to change path to "c:\program files\myapp1", but it alwasy install to default path ""c:\program files\myapp"".
Attachment is my install file.
Can you help to take a look?
YT
myapp.aip
(17.04 KiB) Downloaded 781 times
liuyt1
Dan,
Did you get chance to take a look for this issue?
YT
This is happening because your application resources files have been added under the Program Files x64 folder. Please note that you should add the resources files in the Application Folder. Please see the attached image for your reference.
You can also take a look on the Paths of the folders in the "Files and Folders" Page article which may be useful to you.
liuyt1
Dan,
Thanks a lot.
That solve the issue.
YT
You're welcome,
