vjmittal08
Modifying Updaters Through command line
This is an updates type project. Is there any way to edit the fields boxed in blue from command line?
Re: Modifying Updaters Through command line
I'm afraid we don't have a command line support for editing the requested fields from an updates configuration project. I've added your request on our TODO list and hopefully such improvement will be considered in a future version of Advanced Installer. Thank you for your suggestion.
vjmittal08
I was able to do it using vbscript. Just in case anyone else wanted a way to do it now . . .
New command line options are available for editing the updates configuration projects. You can check all our currently available command line options in our "Updates Configuration Commands" article.
New commands that allow you to configure the Update Configuration Project through the CLI are available starting with the version 14.2 of Advanced Installer released on July 26th, 2017.
