chandrabhushan
using an exe file in advanced installer for find and replace across folders
Hi Team,
As per my installation i need to search and replace files across the folder structure . to do this i am utilizing the fart exe (tool which finds and replaces )
in the cmd command prompt i am able to do it by typing
fart.exe location >FART -i -r "D:\WIP\*.bat" text_to_find Text_to_replace[APPDIR]
so to do that in advanced instraller my steps are following
1. launch attached file
2. attached file = {attached file location }
3. file type =executable
4 command line = -i -r [APPDIR]*.bat TEXT_TO_FIND [APPDIR]
THIS IS NOT WORKING .(See the attached image )
Please advice with the proper command or procedure to do so
Re: using an exe file in advanced installer for find and replace across folders
Please note that the fart.exe custom action is of Immediately one. Although it is added after the Add Resources group, the files are not yet copied on the target machine. The files are copied on the target machine during the deferred phase. So, can you please set your custom action execution time as When the system is being modified (deferred) and see if the behaviour still persist?
By the way, have you noticed our predefined Text File Updates support? A Text File Update can be used to either create a new file with the specified content or to modify those existing using "Append" and "Search & Replace" operations.
If you need any help, please let me know.
You're welcome,
