Schultz
Error during virtual machine configuration: shared folders.
I try to run my setup package in Hyper-V. But it do not work. "Error during virutal machine configuration: shared folders."
My envioment:
Windows 10 (Host and Guest)
Integration Services enabled
Thank you for help!
Re: Error during virtual machine configuration: shared folders.
This may happen when the setup you want to repackage resides on a drive root of your host machine. When repackaging in VM the Repackager cannot handle the case when the repackaged setup resides on a drive root on host machine. This is a Repackager limitation. If this is the case, as a workaround, you should just move your setup into a subfolder of the drive root.
Let us know if this helped.
Schultz
Thank you!
But the Setup is not located in the root Folder. The solution works not for me.
I've tested the scenario using AI 12.3.1 and everything went fine. Can you please download our latest version of Advanced Installer (12.4) and test again the repackaging operation? If your maintenance plan doesn't cover our latest version just install it in trial mode.
If the error still occurs, then please send us an email to support at advancedinstaller dot com and we'll get back to you with a download link for a debug version of AI which can log more information about this error.
Schultz
Thank you! I use the latest Version. I send you an E-Mail...
