h.hasenack
Remove old application defaults
Hi Dan,
I am reworking the installscripts now using Advanced Installer and I am verry happy with the difference from installshield.
I have a question though: I found the ‘allow side by side’ option for upgrading. But the upgrade dialog defaults to keeping the old version, whereas I would like to have the “Remove old version” as default setting.
How can I do this? I seem to be unable to find it in the manual.
Hans
Kind regards,
Hans Hasenack
S&G Asset Management
Netherlands
Re: Remove old application defaults
Hi Hans,
In order to achieve this, you can go in the "Dialogs" page, select the "Yes, remove older versions" radio button from the "UpgradeDlg" dialog, then set the "Selected" attribute to "True" in the "Properties" pane from the right.
h.hasenack
Phew... that simple! Thx
Kind regards,
Hans Hasenack
Netherlands
You're welcome Hans.
