NovaES
[Help] I migrated to another PC and I get this icon on my project
I have migrated from PCs because riding the entire project where you left me short of resources. Well, I copied everything including translation dictionaries and all my settings.
When I open the project file and go to the project or to register my project too, me the icon appears with an X as in the picture.
For what is this? I did not appear before the icon.
Thank you
x image.PNG (4.38 KiB) Viewed 4159 times
Re: [Help] I migrated to another PC and I get this icon on my project
That icon means that the "Folder Removal" operation is set for your folder. In order to disable that option you can right-click on the folder, select "Properties" then go to the "Operations" tab.
NovaES
Eusebiu Hello,
I have to clean me as folders when the application is removed except when I make a migration not touch anything.
Is it because of that then, no?
I thought it was missing some setting or something. I got scared..
Thank you
You're welcome.
I'm not sure why the icon was not displayed on the old machine, but you have nothing to worry about.
