santoshadvanceinst
Default Value for Text Box
I want to set a default value for the text box using Property Default value but I am not able to do it. Am I missing something.
Attached is the screen shot of what I am trying to do. Instead of Path Edit I want that to be set as "C:\Inetpub\.......".
Please help.
Re: Default Value for Text Box
I'm afraid that a default value cannot be set for the "APPDIR" property in that dialog. In order to achieve this, you can go in the "Install Parameters" page and write your default path in the "Application Folder" field.
santoshadvanceinst
Thanks for the update. Will check and let you know.
