GRCD
How can insert two dialogs in First Install section
Hello everyone !!
I want to insert the "ClientServerDlg" first and "SetupTypeDlg" (in this order) in te "First Time Install", but when i try to insert one (using <Add Dialog>), the other dissapear... What i am doing wrong?
I'm using A.I. 11.18 bulid 62156
Thanks and regards from Tenerife, Canary Islands, Spain.
Guillermo
Re: How can insert two dialogs in First Install section
Hi Guillermo,
Indeed, the encountered behaviour is correct. These dialogs are mutually exclusive. Why would you need to add two similar dialogs as their functionality is almost similar?
GRCD
Hello !!
Why are mutually exclusive? I need that the user selects the installation type first (server or client), and then choose the features for the server or client.
Some features will be shown or not depending on the type of installation selected
Guillermo
Hi Guillermo,
In my previous reply, I advised you to use the ClientServerDlg. This will automatically create the corresponding features in the Organization page. There, you can add your existing features under the new ones (e.g. Client, Server and Common).
You can also take a look on the Move and Share components between features video to visually discover this functionality.
