McKool
ADDLOCAL in command line
Hello Support,
I have a (probably silly) question. I'm using AI 12.1 to create a Setup that should be configured over command line. I have defined several features all with install level 4 (Not installed per default). When I launch the setup over command line using ADDLOCAL, then the "Resume Dialogs" appear as if the installation was interrupted before. Not using ADDLOCAL wihtin the command line causes a normal behavior, i.e. showing the "First Time Install" dialogs.
Do you have any idea of why this is happening and of how I can avoid showing the Resume dialogs?
thanks in advance,
Keneth
Re: ADDLOCAL in command line
Hello Keneth,
Please note this is the default Windows Installer behavior and it cannot be changed.
McKool
Hello Daniel,
thanks for your reply.
Daniel wrote:Please note this is the default Windows Installer behavior and it cannot be changed
Not really. This is not normal since specifying features over the command line must not indicate a "resuming" of an installation that has not been started yet. This is logically wrong.
Actually I am re-writing an old Msi project written using "Wise for Windows Installer 7". Passing the ADDLOCAL to the file generated by the old Wise project doesn't show this problem.
I will really appreciate any help or tip you can give on this.
Kind regards,
Keneth
McKool
I found the problem:
Condition for ResumeDLg
Hello Keneth,
First of all I apologize for my previous misleading response. I've talked this with our development team and it seems that, indeed, we choose whento display the "ResumeDlg" dialog. The "ResumeDlg" dialog is set when the following condition is true:
RESUME OR Preselected
To achieve what you want, as a workaround you can proceed like this:
1. go to "Table Editor" page and select the "InstallUISequence" table
2. edit the condition of the "AI_SET_RESUME" action like this:
RESUME OR Preselected AND (NOT ADDLOCAL)
3. rebuild and test the project
Please note that our "Table Editor" feature is available only in an "Enterprise" or higher project type.
McKool
Hello Daniel,
thanks for your help. I had modified already the condition by removing the "OR Preselected" part (I do have an Enterprise License). Since I did that change the setup is working as expected.
Daniel wrote:1. go to "Custom Actions" page and select the "InstallUISequence" table
you meant "Table Editor", don't you?
Keneth
Yes, I've edited my previous post accordingly.
