sonu
Controls toll box is not visible
please verity and provide the solution
Image Description.png (136.39 KiB) Viewed 2279 times
HI team,
Controls toll box is not visible to create "static text fields , buttons, etc."
Please find the attached screen shot for reference ,verity and provide the solution
With regards,
Pradeep
Re: Controls toll box is not visible
Hello Pradeep,
I'm not sure why you encountered the this behavior.
In order to have a better view about this, can you please send us the .AIP (project file) to support at advancedinstaller dot com so we can investigate it? If it contains confidential information you can send us a small test project which reproduce this behavior.
