Kvint
Installing FTP sites destroys my current websites
Hi
I'm having trouble with a small pakage i've made.
The installer is just for setting up a FTP site with some virtual directories under it.
No other settings is made for the default website.
See the attached sceenshot.
When I install this pakage my current IIS Websites stops working.
It seems as if the physical path for the websites is set to the ftproot instead of wwwroot.
Any idea why this typ of installation would break my current iis websites?
Have I done something wrong in AI?
Regards
Joakim
AI ftp.png (48.84 KiB) Viewed 2668 times
Kvint
Re: Installing FTP sites destroys my current websites
I solved this by my self =)
I forgot to change the Binding. The port was set to port 80, the same as the website, wich caued the problem.
I'm glad you got this working by yourself. If you have other questions, please let us know.
