Zsolt Kollarits
Advanced Updater progress doesn't show real progress
Hi Advanced Installer Support Team,
I've noticed a small UI issue with your Advanced Updater: after our update appears and I click on the Next button, you show me a progress dialog but it never shows me the real progress. The installation time of our product is approx. 1,5-2 minutes, your progress strip remains at 0% during this time and it jumps immediately to 100% when the installation is ready. Our customers are not able to see whether anything happens in the meantime or not, they might have a feeling that update procedure is frozen or something. I think we can agree in that a progress strip which continuously stands at 0% for 2 mins is not looking good at all in terms of user experience.
Do you have any idea what can be the reason behind the described behavior? Should we modify anything in our project to improve it?
Thanks in advance for your answers!
Zsolt
Re: Advanced Updater progress doesn't show real progress
Hi Zsolt,
Can you please tell us what theme are you using for the installation package?
Zsolt Kollarits
Hi Dan,
We haven't modified any themes so far, so it's very likely we use your default theme. I think the progress line should move slowly anyway along with installation status, theme is no relevant here, right?
Zsolt
Hi Zsolt,
The progress bar change length as it receives progress messages. This is the default behavior for Windows Installer. However, if you are installing a prerequisite (e.g. feature-based prerequisite which is before the main package installation), no progress can be determined.
Please note that a corresponding action text (for all standard actions) will be displayed on ProgressDlg dialog (during installation).
Zsolt Kollarits
Hi Dan,
I'm not 100% sure if we are talking about the exact same thing, actually we just would like to update our product using your Advanced Updater feature. In order to achieve this we
1. Enabled your updater ("Check for updates using Advanced Updater" checkbox) in our main .aip project and configured all the necessary settings there.
2. Created a new project that can produce updates configuration files.
3. Created a new Update (single EXE file) in that project and generated an updates config file.
4. Launched your Advanced Updater exe file by pointing to the updates config file. -> Our update is visible as expected.
5. Clicked on the Next button at that dialog. -> Your Advanced Updater displays a progress dialog but the progress line never moves. -> Nevertheless our product is successfully installed by Advanced Updater when the progress dialog disappears after a certain amount (2 mins) of time. Note that progress line was not "loading" in that 2 mins.
Do we have to configure anything else for your Advanced Updater progress dialog? I haven't read anything regarding this when I've checked the documentation of your Advanced Updater feature.
Zsolt
Hi Zsolt,
First of all I apologize I misunderstood your scenario.
When the InstallingUpdates dialog of the Updater is displayed, the progress bar should have an indeterminate progress. Please see the attached image:
After investigations it seems that the indeterminate progress of the progressbar it is not displayed if the upgraded version is already downloaded. This seems to be an Advanced Installer issue. A fix will be available in a future version of Advanced Installer, thank you for bringing it to our attention.
So, if you download the upgraded version for the first time, the indeterminate progressbar is properly displayed. Only if the file is already downloaded and the updater does not have to download it once again, the indeterminate progressbar is not displayed.
Can you please confirm this is your case too?
Zsolt Kollarits
Hi Dan,
The scenario you described is exactly what we´re trying to do: we download all necessary resource files (exe, msi) and then trigger Advanced Update by working with file:// protocol, Advanced Updater does not have to download the files, just install them.
A fixture for this in the near future would be really appreciated!
Thanks in advance,
Zsolt
Hi Zsolt,
A fix will be added in the next version of Advanced Installer.
However, it seems this behaviour occurs in the 12.4.1 version. Until the fix will be available, can you please copy the Updater.exe from the installation path of Advanced Installer 12.4 (e.g. default installation path is C:\Program Files (x86)\Caphyon\Advanced Installer 12.4\bin\x86) in the installation folder of Advanced Installer 12.4.1 (e.g. C:\Program Files (x86)\Caphyon\Advanced Installer 12.4.1\custact\x86) and see if the behaviour still persist?
Zsolt Kollarits
Hi Dan,
There is a bit of confusion here, as we use Advanced Installer 12.3.1 currently (not 12.4.1). Do you think the problem you found is totally different from ours?
Zsolt
Hi Zsolt,
I've thought you are using the 12.4.1 version. I didn't tested with an older version. In this case, you can try to install the 12.4 version and copy the Updater.exe from 12.4 to the installation folder of the 12.3.1 version of Advanced Installer. Rebuild your project and see if the behaviour still persist.
This was fixed in version 12.4.2 of Advanced Installer released on September 23rd, 2015 .
